Port & Polish = Flow Bench?
- mx3autozam
Re: Port & Polish = Flow Bench?
^^^simple answer is that the de valvetrain works good and cures our valve floating problem and its cheap to do. The Ferrea setup is like $1400
93 Mazda MX3 KLZE Turbo
I don`t freqent the boards enough to post day to day and I apologise in advance.
Milling the KLZE head`s to increase CR ( compression Ratio ) is a waste of time as you
lose that lovely combustion chamber area that promotes good swirl.
On a side note I have raced engines at 10:1 and the same engine at 18:1 the
hp gain on the dyno was there, the reliability HELL NO! and the blend that went
in the tank was enough to make your eyeès water!!
I personally do not have a issue of timing problems as I have adjustable gears for
both cams ( totally trick stuff )
The ports as Seven has stated and I have in a previous post are simply to big!
Rasing the floor of the port on a flow bench has gain results, but then you have to
change the shape of the intake mainifold to match.
Knifing the devider creates a lot less reverse action in the intake pulse.
( engines are not constant flow they pulse, air flow starts and stops )
I have always polished my combustion chambers to a mirror finsh and my
ports have always had a bead blast finish, though one trick on a motor
that simply would not atomise the fuel was to cut two slots arouns the port
about 0.40 wide and 0.40 deep to create ridges to promote turbulance.
- mx3autozam
pics of these totally trick cam gears you got
- se7en
hmm, I can't see em.
- marcdh
meh well I was bored waiting for parts to arrived so I went ahead and knife edged intake ports, removed intake casting lines, smooth inside transition. On the exhaust side I removed the cast lines, smoothed the machining into the cast and semi polished it. I expect FA gain really, but there was alot of bumpy cast defects that the previous carbon was latched onto, so I did it to prevent that more than see a gain as such. I'll no doubt get a dyno, but don't have an original to compare to!
View Worklog
View Worklog
Sorry Seven try this link its a posting from my earlier nick that was on the boardsse7en wrote:hmm, I can't see em.
http://www.mx-3.com/phpBB3/viewtopic.ph ... 23#p390623
Once again sorry......but enjoy the pics.
ok i see the hump on the floor of the intake side on the ze heads...can that be grinded flat or will it protrude into a coolant passage/oil passage....otherwise i 'll just polish it
93 mx-3, hybrid de/ze-turbo P&P'd ZE heads,9.2:1 CR,garrett t3 57trim .60/.63,HKS SSQV bov, turbo xs 38mmW/G,24in downpipe,sts,13lbfw,sleeper FMIC,65mm TB,Walbro 255lph FP,F&R strut bars, ngk plugs/wires
p/s,a/c,cruise,vris delete..all go from here
