Posted: February 24th, 2007, 6:24 pm
[quote="nolig2278"]if the only difference between 2 bpt mx3 is the size of the turbo and both have 10psi then they should be equal. now which one will get to 10 psi first is another story. small turbo will spool up faster, les turbo lag but it can also be a limiting part. A large turbo will swallow a good amount more air faster once it has spooled up and pull in more air within a given time than a smaller turbo.
of course i would prefer a larger turbo but to say that 2 otherwise equal cars running 10 psi, should both be putting down the same hp on a dyno[/quote]
just for the note i have a BP-DE n/a version (but boosted) i don't have a BPT waste of money in my opinion. nothing in my enginebay is OEM but the BP-DE & f-series trans & axles everythink else is all aftermarket
