MX3 RPMS went from 2700 to 0 while driving...confused!!!!!!!
No thats a classic distributor failure. Tell me how a tach has anything to do with your fuel pump?
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- mx3autozam
it could be a fuel syetm problem baught I doubt it. Could be a bad fuel filter or dirty injectors. You could try a new filter and some injector/fuel system cleaner. A fuel pump will usually work or it doesn't simple as that.92MX3black wrote:does any one think this could be the fuel system??? fuel pump or so on?>??
John
93 Mazda MX3 KLZE Turbo
hgallegos915
I go with faulty distgributor. The tach signal comes from the DISTY. When i was having hei issues it did this exact issues,. even if it was injectors the tach would NOT go up and down that FAST.. do the hei mod .. you wont regret it. saves you around 275 dllrs.
-hec
HEI mod is hack if you're selling the car at some point.... I'd buy a used disty myself (oh wait, that's what I did)hgallegos915 wrote:I go with faulty distgributor. The tach signal comes from the DISTY. When i was having hei issues it did this exact issues,. even if it was injectors the tach would NOT go up and down that FAST.. do the hei mod .. you wont regret it. saves you around 275 dllrs.
I bought a new one... $225.. but thats for a 94. THe 94's are $350+ now
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- jschrauwen
Just a thought. if the Crank Position Sensor(s) go, it would be detected by the ECU. This would indicate to the ECU that the engine is no longer turning over and will therefore shutdown the flow of fuel from the injectors - immediately. There's a crank position sensor inside the disty and one located near the coolant filler neck beside the cam belt cover. Like I said, just thinking out loud FWIW.
hgallegos915
well of course if YOU DO sell the car its nice to tell the buyer what you did. This assures that buyer that the distributor wont go out as easy as before.
crank position sensor i say! (camshaft too)
-hec
- mx-3_rider
if ur car turn off while u where driving its ur disty forsure not enough spark... that wat happen 2 my 6 while going 2 vegas.... disty no matter wat...
96 eclipse GST
future 93 mazda mx-3..
next year 91 toyota supra turbo..
nobody else thinks it could be the knock sensor
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
- Flinch
what if you had a suvere vacume leak? like one that you might not notice thats after the VAF.
-KL31 stock internals with curved neck intake manifold and KL36 ecu
-Turbo running 7.5psi
-FMI 3"x12"x32" all alluminum and welded, have a 7.5 PSI spring she just creeps on cold nights
-ACT 6puck sprung/96 probe tranny
-Short shifter
-HEI and MSD 6al (makes a big difference when you spend the 65$ ont he right spark plugs)
-KYB GR-2 struts with H & R springs
-Megan racing seats
-Personal 280mm stearing wheel
-Familia rear strut tower bar
-Short shifter
-Megan racing seats
hgallegos915
Well i drove without a knock sensor for a while.. all it does is retard the timing and car goes into limp mode. Car will still run fine without it just horrible gas mileage.
-hec
reallyit made my car die when it had a poor connection, also wouldnt start until it was connected... maybe my timing was/is off also.
4 mx3 GS SOLD-
4 mx3 GS SOLD-
- mx-3_rider
