Page 2 of 4
Posted: August 27th, 2006, 1:19 pm
by Shades
I would personally oil the filter as the oil actually helps trap some of the small particles from getting into the engine.
Posted: August 27th, 2006, 2:06 pm
by Bochek
that is true, BUT it also restricts air flow.
Posted: August 27th, 2006, 9:06 pm
by SpikeDerailed
I have considered a CAI, but that whole potential to hydrolock the engine.
Posted: September 9th, 2006, 1:26 am
by reprobation
I've had the same CAI for about a year and a half.. never have I ever had any issues.
Also, this kit looks aso though it is the same as mine.
Mine came in a plain white box - with exactly the same stuff yours did.. Only I paid about 25 bucks for mine... Remember, you pay for packaging and printing.
This kit was sold as a CAI for a SOHC - there was no modifications needed other than having to buy a 2.5 to 3" adapter for the MAF.
Also, I used the filter it came with for about 4 months - it was fine. Afterwards I switched to a 3" Universal K&N - made a believer out of me - car has an even DEEPER tone from the engine bay, and alittle bit swifter (not much, but if feels like it).
Either way, with this kit installed - makes the car sound just damn evil, especially around the 4-5k RPM range...
-Chris-
Posted: June 24th, 2007, 9:16 am
by jamesmx3
i got the same kit, the $50 one and installed it different to all of you guys:
i changed it today so it looks like all yours but i cant work out how to do the black plates, did you use both?
Posted: June 24th, 2007, 9:29 am
by SuperK
The black plates can be a hassle to get the bolt holes lined up, but they will line up. Take off the coolant resevoir and arrange the plates until they line up right above where the filter rests
remember to use that huge rubber... grommet that they include that wraps around the hole... I didn't put mine on for a while, and the rub on the piping wasn't very pretty
Posted: June 24th, 2007, 9:38 am
by jamesmx3
thanks, i'll have a go at it tomorow.
Posted: June 25th, 2007, 5:49 am
by zCat
Important question, original poster: It didn't adversely affect your idle at all? All that factory vaccuum crap hooks up to it right?
If it does, I love you. I mean...like...in a brotherly way.
Peace.
Posted: June 25th, 2007, 7:50 am
by DJGypsy
zCat wrote:Important question, original poster: It didn't adversely affect your idle at all? All that factory vaccuum crap hooks up to it right?
Peace.
i did not have to adjust my idle at all after isntalling.
there are only two hoses that connect to the intake pipe. one has to be conencted, one does not.
the one that goes from the valve cover to the pipe, i just put a breather filter on the valve cover and i plugged the intake pipe side of the connection with a rubber stopper and i used duct tape/elecrical tape to keep it in place.
the other connection (the fatter one) must be connected, i believe it's part of the EGR system, but i could be wrong. just route the stock hose up to the new intake pipe. it takes a little bit of massaging, but i got mine to fit w/o kinking. i hate how people disconnect the EGR system in favor of performance. under WOT, the ECU bypasses the EGR system by default in favor of this extra power. you don't need to be spewing rediculous amounts of pollution just to cruise around.
after installing the kit, i reset my ECU (disconnect + batt. terminal, pump brake pedal 5-6 times, allow car to sit for an hour +/-, reconnect battery, start car, allow to warm to normal operating temp and then go for an easy drive), and went on with life.
i've had this system on my car for nearly a year, and have had no issues. i DID oil the filter that came with it before installing. i will be switching to K&N in the next few months anyways just because i trust K&N more than i do "John's Super Duper Filters".
good luck!
Posted: June 25th, 2007, 1:22 pm
by onlytrueromeo
How much does one of these affect your gas mileage? Hate to be a penny pincher but Im a poor college student
Posted: June 25th, 2007, 1:26 pm
by DJGypsy
onlytrueromeo wrote:How much does one of these affect your gas mileage? Hate to be a penny pincher but Im a poor college student
IF you can keep your foot out of it, your mileage will improve. i noticed 4-5 mpg improvement on my car, highway and city.
that's just the thing though, can you keep your foot out of it?
good luck!
Posted: June 25th, 2007, 3:05 pm
by ravensteve9
What did you do with the hose that went from the intake tube to the IAC? Also, there is a vacuum hose that went to the stock airbox. What did you do about that? Looks awesome!
Posted: June 25th, 2007, 3:33 pm
by jamesmx3
is the vacuum hose that really small one? i was wondering where that came from it looks like mine broke off the origonal air box. it still runs ok though.
Posted: June 25th, 2007, 7:07 pm
by SuperK
by the way, there is a very small unexplained "mystery hose" that is disconnected on every of our cars.
So if you can't find out where that little guy goes, you just gotta... heh... let it hang.
</innuendo>
If you haven't purchased the kit, most of your answers will be answered when you see the kit. It's very self explanatory.
Posted: June 25th, 2007, 8:43 pm
by Cy
HOLY OLD THREAD
that hose is fresh/non -vaccume air intake for the whole vaccume system...or exhaust...i didn't look @ the vaccume diagram that closely...
