Page 2 of 3
Posted: July 30th, 2006, 1:45 am
by monty73741
TO MY UNDERSTANDING
the bp in the dohc is not a direct bolt in but in a sohc it is a bolt in
jason
Posted: July 30th, 2006, 1:52 am
by ariesdude
monty73741 wrote:TO MY UNDERSTANDING
jason
There are two types of BP -
the early BP 90-94 - has a black valve cover and a separate timing cover - almost direct fit for SOHC
the late model BP - 95-98 - has a metallic gray valve cover and the timing cover is not separate - looks exactly like a 1.6DOHC engine - just bigger - almost direct fit for DOHC
BP from a 90-94 protege
1.8L BP from 95-98 protege
![Image](http://jdmexchange.com/ebayengine/bp3.jpg)
Posted: July 30th, 2006, 4:47 am
by lowflyinmx3
i'm wantin to do this swap. i have a 94. has anyone here swapped in a 95-98 bp. i wanna know before i make my move so that i don't get stuck with a motor that i can't use
Posted: July 30th, 2006, 9:15 am
by MechaManZero
I remember custommx3 getting into it.
Posted: July 30th, 2006, 10:34 pm
by Limegreen mx-3
The reason its a stright forward swap in a 92-93 sohc mx-3 is do to the wiring. You can use the protege LX wiring harness and ecu. Plug it in (NO cutting of the wires, splicing or dicing) and fire it up.
Another reason is if u do it the cheap getto way the org. sohc wiring harness can be used to run the bp but u'll have cut wires extend wires and a extra 2 wires for the VCIS to work and open up ur sohc ecu and solder them to the pins not used in the sohc ecu. if not u'll not get the full potinial of the BP and also the sohc ecu is limited to 6500 rev limit where the bp ecu is 7500 rev limit.
On the 94-96 mx-3 the wiring is a little more complicated
Posted: July 30th, 2006, 10:59 pm
by RbluE_MX-6
xtreme velocity wrote:..i just want a lil more acceration..i dont need top speed..i dont like being slow though..plus im not real good with cars....
You sir, sound like your asking for a 1st gen mx6 GT.
But in all seriousness, a 90-94 BP-DE is plentiful and could be had for around $500. And since you say your father is into drag racing, then I am pretty sure that he knows a thing or two about changing out a motor. Very simple. But keep in mind that the BP in stock form is no speed monster.
Posted: July 31st, 2006, 6:29 am
by xtreme velocity
ariesdude i have a question..y does my motor in my 94, look just like the 1.8L BP from 95-98 protege?? here is a pic of mine..
and RbluE_MX-6, what is there off a mx-6 that u can put on a mx-3..buddy of mine has 1 4 sell..part out..
thanx..
Posted: July 31st, 2006, 10:43 am
by Limegreen mx-3
xtreme velocity wrote:ariesdude i have a question..y does my motor in my 94, look just like the 1.8L BP from 95-98 protege?? here is a pic of mine..
thanx..
Both the 1.6 dohc in ur car the 1.6 sohc in the 92-93 mx-3 models and the 1.8 BP in the mazda protege are all b-series engines. kind of like honda b-series engines b16 b18. the other engine that looks like ur is a1.8 dohc BP that pretty much plugs and play with the 94-96 mx-3.
Posted: July 31st, 2006, 11:28 am
by RbluE_MX-6
xtreme velocity wrote:and RbluE_MX-6, what is there off a mx-6 that u can put on a mx-3..buddy of mine has 1 4 sell..part out..
thanx..
Nothing really, they're apples and oranges. But Im interested in what year and trim your freinds mx6 is.
Posted: July 31st, 2006, 1:56 pm
by ariesdude
the 95-98 BP is very much alike the 1.6 DOHC -just a little bigger - I guess its just part of mazda's engine development cycle
Posted: July 31st, 2006, 2:20 pm
by xtreme velocity
oh..so i guess this is where the saying "looks isnt everything" comes in?? lol..i get it..i was just thinkin..man if that a 1.8 n it looks just like mine then maybe i have a lil more HP than i think..lol..how much horse power does the 1.8 have?? specs on mine say i have 108hp..im j/w..im tryin to read as many post as i can so i can learn more bout cars..my dad never really let me work on cars much..so im kinda a car dummy..bare with me guys..lol..
Posted: July 31st, 2006, 8:16 pm
by MechaManZero
its kinda like saying a honda b16 and a b18 look the same lmao
Re: New Guy..
Posted: July 31st, 2006, 11:00 pm
by NorCalMX3
xtreme velocity wrote:Hey guys im the new guy in the forum..i have a 94' 1.6 DOHC mx3 that is a sea foam green..when i figure this site out a lil more i will post sum pics..nice car, bought it used with 75,000 orignal miles..runs great i havnt had one problem out of it..i want 2 do sum upgrades on it..but im not made of $..so i kinda have 2 do this limited..im only 17 and a senior in high school..so i kinda dont have alot of time 2 work..are there any ideas on wut i could do to make it faster?? its pretty much stock besides rims and lights..nothing to make it faster..but it will pick up the ladies as is..i just want to make it faster..thanks for yalls help..
you and me are in the same boat, cept mine had a coolant leak, bad timing belt, and a little fender damage when i got it. I am an amature mechanic and i was nothin i coundnt fix.
Re: New Guy..
Posted: July 31st, 2006, 11:24 pm
by MechaManZero
mx3TheOnlyLoveOfMyLife wrote:you and me are in the same boat, cept mine had a coolant leak, bad timing belt, and a little fender damage when i got it. I am an amature mechanic and i was nothin i coundnt fix.
Well man, after you start working on it here and there, you will get the hang of it. You can learn many secrets from the other guys on here to do a little here and thee to make her go. I have gone through 5 cars meaning my mx-3 is the 5th. I used to have a '86 Ford Escort EXP and wanted to drop in a 2.2 turbo 626 motor. I also had a 240sx that I beat the crap out of by drifting it. Cars are fun you just have to gain a basic knowlege and go from there.
Best way to learn is to have someone that knows what they are doing on cars help you out. Like you working on the car and them telling you what to do. This way you get that natural hands on experience. It doesn't hurt to try.
Posted: August 1st, 2006, 1:03 am
by xtreme velocity
im not good with them either..but im workin on it..n hands on is the best way 2 learn..thats y i found this site..b/c ppl here know about my car as well as i do..so i can get help..
