klze rev issue
MI-Archangel
- ccreech
There have been several suggestions posted. Have you tried any of these? What kind of help do you want. About all we can really do is point you in the right direction. The rest is up to you. If you have anymore specific questions let us know.XxantwawnxX wrote:Id say check out the TPS and IAC orrr get a whole TB from a junkyard that has a TPS and IAC on it. You can test the TPS and IAC first and explore other options before buying anything.
Re: klze rev issue
what TB is compatable with the klze curve neck engine??? im having the same prob but its not the TPS. Is it the same as the 2.5 mx6 engine???
greenstorm
Re: klze rev issue
just throwing this out there, but a less likely scenerio is leaky intake manifold gasket. mine producted the same problems.
BUT, it's probably what's been mentioned. keep it simple stupid!
what kind of car IS that?
