To ball bearing or not to ball bearing.....that is the ?
Post by Josh »
the BB T3/T04E spools nicely, it will be rare in an AutoX that you will be under 3K all that much. it should work out just fine. thats what the NOS is for anyways. to spool up faster, Right? :D
cjthor
Post by cjthor »
I will have the specs for the turbo monday and will post them . I need help making sure its a good one!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
JWMotorsports
Post by JWMotorsports »
I'd reccomend the Garrett GT28RS for you if you want to AutoX. It is a Dual Ball Bearing oil and water cooled turbo that is rated up to around 350HP. Go with the .64 A/R Exhaust housing for quick response.
Around $1149 for the turbo.
If you choose to run a T3/T04E I'd recommend a 50 or 57 trim Compressor with a .48 A/R Exhaust housing which could make up to 400HP but would be laggier.
Around $619 for the turbo.
cjthor
Post by cjthor »
JWMotorsports wrote:I'd reccomend the Garrett GT28RS for you if you want to AutoX. It is a Dual Ball Bearing oil and water cooled turbo that is rated up to around 350HP. Go with the .64 A/R Exhaust housing for quick response.
Where you get your prices?
Jarid Perry
forcedairram
turbo
Post by forcedairram »
he gets his prices from http://www.cheapturbos.com or http://www.atpturbo.com. You should check it out alot of good buys
Return to “Forced Induction”
