Synthetic Oil - Mazda Engines
- jschrauwen
I'm going to take a wild guess here and say that Chiggles has already got his answer from the previous post from Tunes, judging by the time stamp. Chiggles would have been in the middle of typing his post when Tunes already posted his.
jschrauwen wrote:I'm going to take a wild guess here and say that Chiggles has already got his answer from the previous post from Tunes, judging by the time stamp. Chiggles would have been in the middle of typing his post when Tunes already posted his.
Hmmm.... well, to the best of my knowledge, my car does seem to be well maintained when I got it, and I don't notice any blue smoke coming out when looking back through the window or in the mirror, but then again, I should probably just have a friend follow me around for awhile to take notice of that just to be sure. And I don't think I'm burning up oil at a higher rate than what's expected... like I said, I had my first change done around the time of purchase in November, and only needed to top it back up about a month ago. So I assume burning up my oil to the point where it's low in 6 months is considered a normal rate of consumption, is it not?
That said, assuming my observations are correct and I'm really not having any blue smoke issues, then in my position I should be able to switch to synthetic, yes?
- neutral
Yup, you should be good to go w/full synth as that is very little oil consumption. You describe similar engine maintenance/conditions to my Mazda rides and I've put 60+ km on each of them with 10W30 full synth since purchasing w/160 - 185 km. I have the 95 MX-3 now with 220 km, 90 MX-6 now w/230 km, 96 626 now with 225 km - all running on 10W30 full synthetic and they all run great with barely any oil consumption.
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
- mitmaks
use thicker weight if youre experiencing tapping, oil pressure will rise oil into lifter reducing Hla noise
I found that you don't need to run syn if you change or oil every 3k like reccommened. If you ask me syn is overpriced unless you plan on running your oil for 5k-7k you get the same effect out of a regular oil you just need to change it every 3k. So if you don't run your oil past 3k there is no need for syn.
Teal 1993 MX3GSZE
