fuel injectors for turbo
mx3optidrive
Re: fuel injectors for turbo
Post by mx3optidrive »
Thanks a lot guys for all the help.
Shop 506-577-6708
cell 506-381-3503
email danny@jdracing.ca
mx3optidrive
By the way, I searched and didn't really get a straight answer, the fuel pump I am looking at is from a non-turbo RX-7. Is this the right pump or should I be looking for the turbo RX-7 pump?
Shop 506-577-6708
cell 506-381-3503
maldo
Post by maldo »
Either will work. The NA FC flows less so it is a good option for lower power levels so as not to overflow the injectors. I believe the turbo version is 225lph but could be wrong in that. Either way, it is about 3 times the size of the stocker so some mods to the bracket are required.
OsoSlo z28
Post by OsoSlo z28 »
the 3rd gen is a 255lph and requires a custom bracket (2 adjustable hose clamps will work) and some of the piping has to be cut off to allow the pump to fit all the way in. also, you have to cut, strip, and lug the stock pump wires. the 255 pump has open connections on the pump. kinda scary thinking about open connections sitting in gas, but there's no danger as long as you do it right. :cool:
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
maldo
Post by maldo »
The FD is a beast of a pump, either way, any model of pump for the RX is quite loud so it must make lots of power. ;)
OsoSlo z28
loud=power? man i wish you had told me that earlier. now i need to go buy a softball cannon exhaust....then poke holes in it. :p
"MR." Ashley Fowler
cardomain pics
Shady469
Post by Shady469 »
my walbro 255 for the rx-7 plugged right up to my harness. no cutting. the bottom peice that holds the pump had to be bent a little but other than that it went right in.
Im starting to think my 92 is just ever so slightly different than everyone elses...(i.e. my disty is diff from other 92s)
but yes the pump is really loud.
i went with rc eng 370's that are working well so far.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Return to “Forced Induction”
