Page 2 of 2
Re: Removing Hatch Garnish
Posted: June 14th, 2004, 9:24 pm
by atlantamx3
Originally posted by JeffsCosworth:
i got a wing on it, was an option...
Like this one I am sure...
:shrug:
Posted: June 14th, 2004, 9:35 pm
by MX3-Freak
Agreed, the flow would work much better if the hatch garnish itself was white as well as the spoiler in that pic. Just a thought though. :shrug:
Posted: June 15th, 2004, 5:25 pm
by JeffsCosworth
yes that s this wing... seems bad this color tho...
my hatch is black and sparkle green wing ;)
Posted: June 28th, 2004, 11:20 am
by GoT_DaT_Mx3_Se
I want to get one of those supra stlye wings or maybe a gtr one. i have a special edition with the small wing on it now. is there a garnish underneath the spoiler and will need it to install the aftermarket spoilers???
Posted: June 28th, 2004, 12:44 pm
by perhapsadingo8yerbaby
If this pic is the type of spoiler you currently have, http://www.mx-3.com/se/blue-se.cfm then you do not have a garnish underneath and I believe you would need to have a garnish in place for installing the other wing types you mention.
Posted: June 29th, 2004, 12:40 am
by GoT_DaT_Mx3_Se
thanks for your help!!
Posted: June 29th, 2004, 11:52 am
by JeffsCosworth
i got a 94 RS with hatch garnish and stock wing... can I take those 2 pieces apart ??? (wing and hatch garnish.....)
I want to install my new wing ;)
As far as I know, the RS only have a hatch-garnish, not wing.
nope-mx3
this wing....
<img src="http://img78.photobucket.com/albums/v25 ... orth/1.jpg" alt=" - " />
Posted: June 29th, 2004, 12:03 pm
by seneca
Same kind of question..I have yet to attempt this but...WHat needs to be done regarding the removal of the OEM spoiler? Mine rattles as sin, so I would like to put some sort of shock absorber underneath it, if possible!
Posted: June 29th, 2004, 12:09 pm
by atlantamx3
I highly doubt that your actual spoiler is rattling. It is more than likely the crap-plastic tricm in the hatch area and even more likely to be the 3rd brake light cover.
I had to crawl back there while mine was rattling to find the culprit & make sure that everything back there was secured nice & tight.
Posted: June 29th, 2004, 4:30 pm
Had same prob and turned out to be the 3rd brakelight housing itself that was rattling against the interior hatch surface from a mounting screw that had loosened a bit. Agreed, not likely to be your spoiler coming loose altho the sound would be from the same general area aye.
