oil troubles
dr. gonzo
oil troubles
Post by dr. gonzo »
i just replaced a head gasket. now the oil is a light cream color......what did i do?!? it sealded nicely, and i know its not coolant cause i havent put any in yet, i just started it to make sure it worked. please help. :(
some peoples kids.
dr. gonzo
Re: oil troubles
Post by dr. gonzo »
im assuming some of the coolant got into the block when i had the head off. thats my only logical explanation. what do i need to do to clear this up.
some peoples kids.
TekPmp
Re: oil troubles
Post by TekPmp »
If thats the case, change the oil and check for coolant again?
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
93SOHC
Re: oil troubles
Post by 93SOHC »
you may have to change the oil more than once if a lot of coolant got in there. Change it, drive it for a while, change it again. Blow head gaskets are a b-otch!
dr. gonzo
Re: oil troubles
Post by dr. gonzo »
alright cool, thnx
some peoples kids.
