miata cams
schwankesmx3
miata cams
hey i have the b6ze cams and i dont know what the specs are on them could anyone tell me i tried the dealership and they didnt know soo could some one help me out here and tell me how to swap goes...thanks specs in meanin the lift-duration
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
- Josh
Re: miata cams
intake is 236 duration 7.87mm lift exaust is 248 duration 7.87mm lift. the problem with using stock miata cams in out motor is the cams have to be swaped intake fot exaust. and the cams arnt matched so your going to be taking in more air than you will be releasing leaving air in the combustion chamber. i would get them matched. just me 2 cents
schwankesmx3
Re: miata cams
thanks ... do u know what the stock mx3 cam specs are?
