Car won't start..PLEASE HELP..
I just installed 4 new spark plugs earlier today and the car started. While installing my spark plugs I noticed my upper radiator hose was cracked and was leaking. I then replaced that and of course during the install coolant went everywhere. I removed the intake and the intake essembly that sits on the radiator support and once I finished installing the new hose I reinstalled them. When I was finished I tried to start the car and it would turn over but would NOT start. Any ideas?
- mitmaks
Re: Car won't start..PLEASE HELP..
did you unhook any connections, VAF etc, maybe blown fuse, also check connections where wires go to fuse box it might be loose, wont start
