OK, first of all what kind of clutch disk and flyweel should i put on my bpt?
How do i know if my cpu is programmed right?
what is the normal fuel consomation on a bpt?
what is the best fuel pump i put on it?
how much would it cost?
clutch help and other stuff.
Re: clutch help and other stuff.
almost forgot, clutch and the flyweel would be more for dtreet use and not for race.
- ryanlindenberg
clutch you should use is the ACT street clutch for a 94 protege LX available from corksport.com. flywheel should also be from a 94 protege and the fuelpump you should get is a walbro 190 lph. you could get the walbro 255 lph but it is overkill and is really loud. total cost of these parts is US $450-500
CARDOMAIN WITH UPDATED PICS
I used a EXEDY complete cltuch kit and I am very satisfied, mine is driven every day and I drag hard with my friends all the time, its not a bpt Its a 1.6 dohc with some mods. but I think you will like it and by the way, its affordable.
