will a 94 6 cyl gauge cluster go in my 93 4 cyl ????
chrisx03
Post by chrisx03 »
just wondering cos mine broke =| and i need it heh but i dunno if it will like short circuit or somethign i dunno...plz help lol
papa roached
Re: will a 94 6 cyl gauge cluster go in my 93 4 cyl ????
Post by papa roached »
no, you have a speedo cable, the v6 does not
