what i4 engines came in the mx3
was there only a sohc or was there a dohc also and where all i4's only 1.6? and lastly what years and models have the different engines (if there are different ones) .. i looked around in here and couldn't find out for sure
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
Re: what i4 engines came in the mx3
4 banger RS:
92-93 = sohc 1.6L
94+ = dohc 1.6L
6 cyl GS:
92+ = dohc 1.8L
92-93 = sohc 1.6L
94+ = dohc 1.6L
6 cyl GS:
92+ = dohc 1.8L
2004 Nissan Xterra - Daily Driver
2003.5 Mazdaspeed Protege - Sold
1994 MX-3 RS - Selling
Searching for a new performance car to buy, cant decide.
http://www.sounddomain.com/id/omenmx3
thanks... one more ?
i believe i've been told that a version of the miata has a 1.6? if so are any parts transferable?
ProjectMx
Cardomain
Cardomain
Also if I remember correctly, there were some 1.6L DOHC made in 1993.
- Custommx3
- Site Administrator
Correct in 93 they started with the DOHCs, the earlier model 93s had SOHCs. in 94 all were DOHCs and the interior was changed due to airbags.
how about the interchangability between the internals of mx3 1.6 and the miata 1.6?
ProjectMx
Cardomain
Cardomain
You might have some trouble with the flux capacitor of the serach button but evyerhting else should swap in a odd way or so
-torp.
I don't own a Mazda.
so any turbo items? or stronger internals / better internals from the miata 1.6 would fit in the miata 1.6?
ProjectMx
Cardomain
Cardomain
What Torpedan is saying is...do a search . this has bee documented.
The B6 sohc lacks oile squiters for the pistons and supirior cam profiles. 94+ B6's(B6ZE I believe) have the oil squirters, better flowing head, AND two cams so they handle the air flow and exhaust flow better.
B6T engines have beefier rods and turbo cam profiles better able to handle the stress of turbocharging (i.e. detonation, longer exhaust stroke keeps the combustion chamber temps down, and avoids friction-combustion vs. ignited combustion).
Cheers
Cheers
No Sig
hate using search buttons.. piece of sh@t half the time... instead spent a couple of hours hear and there trying to look straight though everythign and didn't find much answers for the I4 ?s stuff like this should be under the FAQ section i can't believe you guys didn't even have what engines came inthe car somewhere under the FAQ ... should be one of the first things done
ProjectMx
Cardomain
Cardomain
Go ahead and make up a good engine list for the mx-3 and I am sure it will be put in.
well i've already made a suggestion to the webmaster and haven't heard back.. might make another.. its something we need... plus info on what can be done with the 1.6 if any one is interested on some info on the miata 1.6 and other mazda engines : http://members.aol.com/solomiata/MX5Engine.html
ProjectMx
Cardomain
Cardomain
i'm guessing the 92-93 uses obdI .. but does the 94-95 use obdII?
ProjectMx
Cardomain
Cardomain
i wrote up a good mazda engine list a couple weeks back..no one seems to care though. it got no replies
click a couple pages back for a thread titled "Mazda B-Series engine codes explained"
<small>[ November 30, 2003, 06:14 PM: Message edited by: Gro Harlem ]</small>
DONATE TO MX-3.COM
DONATE TO MX-3.COM
obdII started in 96Originally posted by mazda78:
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
