323 tranny
323 tranny
Would a 1988 323 5-speed fit my 95 mx3? I think it is just the plain 1.6L non turbo. I can get the tranny for $100 so I need to know if this will swap into the car before I get it. Thanks.
Re: 323 tranny
Does anyone know if this will work? I can get a real good deal on everything. Anyone, help, please.
- papa roached
Re: 323 tranny
from what i know, this should work
Re: 323 tranny
it will work in the mx3. i used a 323 tranny in mine
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
