what is the right gear
wu_tang6931
Post by wu_tang6931 »
ok to all the automatic owners out here or any one that can answer me. what is the correct gear supposed to be when you are going up a steep hill. is it S or L? thanks
Casino
Re: what is the right gear
Post by Casino »
D seems to work for me :) j/k<BR>um I dont know you could check in your owners manuel it has all the information on L and S and when you should use them.<BR>I only use them when im driving in snow and ice so that the transmission does the braking
http://www.realtimeperformance.ca
03 miata, formally bottle fed 96 DOHC
Sonicxtacy02
Post by Sonicxtacy02 »
L is for low speed incline S is for high speed incline. Use L if you have someone in front of you and your speed is varying instead of increasing. S is for when your wide open and can more freely increase speed on the incline
Shaun Newman
wu_tang6931
ok thanks. cause the weather is getting bad here and my apartment is on a really steep hill.
