Exhaust Manifold from SOHC to DOHC Fit?
I have a DOHC Exhaust Manifold will this fit on a SOHC, I think it will because I know the B6T Turbo Manifold will fit either one.
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
Re: Exhaust Manifold from SOHC to DOHC Fit?
I believe they are interchangeable, I don't have my head here to compare. I know that the intake manifolds are different for some reason.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
hey maldo...you just did a b6t swap right? Well if you still have your old engine, could you sell me your exhaust manifold?
R.I.P. September 25th @ 2:55 p.m. - 93 Mx-3 RS ![Sad :-(](./images/smilies/icon_sad.gif)
eh? i know this is an old post, but the guys at corksport told me the DOHC exhaust manifold wouldn't fit my SOHC...i'm confused
Well, seeing as how I just yanked my turbo and manifold off today, maybe if I remember I will try to test fit my old sohc manifold to the b6t and will let you know.
Chris Malden
MX-3 RSR
MX-3 RSR
I checked things out for you, won't fit. The holes for the studs are at different areas, not only that but the manifold is a little on the small side for the dohc exhaust ports.
Chris Malden
MX-3 RSR
MX-3 RSR
that's what i thoought, but i wasn't sure...thanks maldo
