engine problems broke down by road
marshmallow15
hey guys. i was driving, pushing it a little more than usual and then all of a sudden the engine stopped running but the car was on, so i pulled over. i opened my hood and smoke was coming out of the headers and one of my radiator fans were not spinning....the fluid coolant was leaking in the past 2 weeks as well. well it didnt start up and i had to get it towed so i dont think it was overheating problems. any ideas what happened?
- team slideways
- team slideways
OsoSlo z28
Re: engine problems broke down by road
it's possible that your coolant hose busted and that's what created all the smoke. if this is the case, then it's possible you overheated the car. this might not be the case at all. if you could, describe it a little better....
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
marshmallow15
yea maybe it is a busted coolant hose because my radiator's been leaking my green coolant fluid lately like crazy....maybe its that. thanks crev ill check up on it tomorrow.
- team slideways
- team slideways
canadian_ice
If your engine overheated, wouldn't you notice that on the guage in your car? Or did you...or weren't looking at it?
marshmallow15
the fuel/temp gauges in my car arent working because of the needles.
- team slideways
- team slideways
heavyfreak
if you fill it up and it still is leaking its your water pump.. you dont' see it leaking cause its covered by the timing belt cover.... <P>hit.. to get the boss pulley bolt off.. put a long handel ratchet on it.. and crack the car.. it'll hit the bottom frame.. and lossen the bolt..
boostedmx
the engine probably seized up from over heating. gotta have coolant. a busted hose would not make it stop running.
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
