2nd gear noise??
2nd gear noise??
I have a type of screeching noise coming out when i shift into 2nd. It doesn't do it in any other gear, just at the start of second and it only makes the noise for a second then it goes away. Anyone ever had this problem? I don't really want to take it in and have them charge me an arm and a leg to fix something i can do myself. Any help would be greatly appreciated. <BR>thanks<P>[ May 30, 2002: Message edited by: k2stp ]<p>[ May 30, 2002: Message edited by: k2stp ]
I wasn't born to drive I was born to work, but I got laid off;)
Re: 2nd gear noise??
Weird, I kind of have the same problem with Shifting into First, and My problem is because my clutch is gone, so that could also be your problem, When you power shift, does your clutch grab tightly? or does it slip alittle bit? if it slips a bit, then your clutch is gone and needs to be replaced and I hope you can do it yourself because if you can't then it will cost you an arm n a leg ![Surprised :eek:](./images/smilies/icon_surprised.gif)
1994 Mazda MX-3 RS (Project RS-T)
