Injectors??
Injectors??
WIth the fuel rail out and injectors on and cranking the car.Should the all injectors open and close the same time or should they open and close according to cyclinder thats gonna be fired.By the way my car has all 4 openin and closin at the same time.
- Zoso124
Re: Injectors??
yes they "should" each spray the same as the firing order. Hmmmm this is a good question<P>1st Rail 1 3 5<BR>2nd Rail 2 4 6<P>And I sure would hope you mean all 6 are spraying.
Mike Evans
Gone:
Gone:
Re: Injectors??
Putting a 4cyl tech question in the V6 forum is a guaranteed way to get a wrong answer.
David Coleman
