Need Experts HELP!!!!!!
jojo2k23
Post by jojo2k23 »
My car has sat for about 3 weeks.I havent been able to locate the problem.I have spark,timing has not been changed,air,fuel(spark plugs are getting soaked in gas).My a/f meter is good according to the test in my manaul,coolant sensor is good,I have pulse at the injector wires.What do ya think?I forgot to mention that i bought a ECU because everything seems to be ok in the engine compartment but its not the ECU.HELP????
torpedan
Re: Need Experts HELP!!!!!!
Post by torpedan »
First off how about a CLEAR description of what your problem actually is.<P>What did you do to your car before it happend How many miles are on your car, and do you know the past servicee history of it.
-torp.
I don't own a Mazda.
Stevech_2001
Post by Stevech_2001 »
first if the plugs are wet with fuel and there is spark that means that there should be combustion.....I would think there is something with the ignition that isn't working correctly
Steve
