1.6l sohc swap
hartattack
1.6l sohc swap
I was wondering if it was possible to swap in the 1.6l DOHC to a car that previously had the 1.6l SOHC, is this swap possible? If so, what would I need and how hard would it be to complete? Thanks for your response. hart373@hotmail.com
maldo
Re: 1.6l sohc swap
Check out my site in the signature. I swapped in the B6T motor to replace the sohc. Works great, the NA B6 motor would be similar but without the need for a different computer and all the turbo parts.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
boostedmx
Re: 1.6l sohc swap
i did the swap and a new wiring harness and computer will be needed. really not worth it. if you want drop in hp get the b6t. the b6 is the same block so you could get it for a whole lot cheaper if your gonna upgrade the turbo anyway. and the head flows better on the na motor.
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
hartattack
Re: 1.6l sohc swap
thanks for the info, what is your site??? boosted, since you have done the swap, how easy was it? or if you paid for it to get done, how much? thanks again,
boostedmx
Re: 1.6l sohc swap
it is real simple but like i said it can get expensive quick due to ecu and wiring harness not working.
hartattack
Re: 1.6l sohc swap
thanks again for writting back, so what exactly is the wiring harness and ecu? how much would it cost to replace these so that it will run the DOHC? thanks
boostedmx
Re: 1.6l sohc swap
engine, ecu, and wiring harness and down pipe, air flow meter and intake, everything else bolts up mounts are the same
boostedmx
Re: 1.6l sohc swap
yup
hartattack
Re: 1.6l sohc swap
but what about the harness and the ecu, how much do they cost and were can I get them at? are they easy to install to? thanks again.
