Need advice on my Brake Rotors
I bought some KVR brake rotors in Oct. I noticed that they are producing something like rust(ok I'm in denial). Can someone tell me what I can do to get rid of this stuff or at least give me someother options. Maybe even recommend some new rotors which wont produce the Rusty color.
- jaydog5678
Re: Need advice on my Brake Rotors
Where exactly is the rust on the rotor? My Power stop rotors only rust when they are wet, but when you drive on them the rust goes away. There will be rust behind the wheel but I would'nt worry about it unless you just don't like the way it looks. As far as performance goes, they should work fine. Changing rotors will just have similar results.
Well the rust is appearing on the part behind the wheel. The performance is fine. I just was wondering if there were ways to either remove it or prevent it. Thanks for your reply. [img]shrug.gif"%20border="0[/img]
- jaydog5678
I Don't know of a way to prevent the rust, but there is plenty of way's to remove it.
