backup light on
backup light on
Does anyone know where I can disengage the reverse light? For some reason, it is always on. I can't even find out how to take out the bulbs for the reverse lights.
Re: backup light on
Is the tranny auto or stick?
Re: backup light on
tranny is stick
Re: backup light on
The back-up switch is located on the transaxle casing. Look on the front drivers side of the tranny and you should see the switch with two wires coming out of it. I imagine you will just have to replace the switch itself. It might be in the online manual if you can't find it. Good luck.<BR>P.S. sorry couldn't be more help, but my Chilton's doesn't go into too much detail.
Re: backup light on
thanks for the help, some help is better than none when I started. I'll look for the switch.
