Clicking noise
Clicking noise
I hear a clicking noise everytime I press on the brakes...has anybody else had these problems and have any ideas to fix this?
1sT EvEr Mx<BR>BLaCk WiDOw!
- cjthor
Re: Clicking noise
Hello....<BR> Check the brake caliper hardware. There should be a clip on the brake pad to the caliper itself. Also make sure that the calpier bolts are tight. If you need.. I can take a pic of my caliper and send it to you. Good luck.....<P> Jarid Perry<BR> 94 Blaze Red RS<BR> 15.02@96.7
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- Custommx3
- Site Administrator
Re: Clicking noise
there is a metal wire spring that is shaped like a "W" that is used to press apart the break pads in the caliper. If that metal is rubbing the caliper it will click. I just bent mine away from my caliper a little.<BR><P>------------------<BR>Barry Clark<BR><I><B>Moderator</B></I><BR>1995 Mazda Mx-3 RS<BR>Chaste White<BR><A HREF="http://www.barrykclark.com" TARGET=_blank>barrykclark.com</A> <BR> custommx3@usa.net
Re: Clicking noise
Hey I took Out My brake pad wires , I didnt know I needed them and now everytime I turn a sharp corner, you can hear a noise from the front brakes, kinda a streching kinda noise, JArid Can Youi Send Me a pic of the Caliper?
