will this Turbo kit be the one?
I think I would be able to hook everything up no problem.. but would it have to be tuned afterwards? (most likely) and how do I tune it
what els would I need? and is there a cheeper kit ?:P
these kit aren't bad as far as piping and stuff go. but usually a cheap turbo, shitty wastage and BOV.
if you wanna go this route your probably better off buying the hot pipe from ebay and a intercooler kit. and piece the rest together.
You would still need some kind of Fuel management. Megasquirt is the most popular with KL engine. bigger injector end fuel pump.
I strongly recommend getting Megasquirt, get familiar with it, then turbo!
AZ-3 1498cc Turbo! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt Mx-3 2.5 V6 Turbo 291 BHP 251 lbft @ 8psi - Retired due to rust and back at uni View Worklog
