Take your spat looking like this:
Cut around this much out of the spat, and also remove the tabs on the inside. I used tin snips for this:
Make yourself up some brackets and small nut & bolt sets:
Give them a scrub down with scotchbrite and warm soapy water, before painting:
and refit once dry:
Only thing missing from this write up is some trim tape of velcro to hold the end up:
Wheel back on, put car back down, make a brew and stand back and admire the subtle changes:
