Did someone say CF hatch? :p
Carbon Fiber products part 2
Re: Carbon Fiber products part 2
- kulluminati777
That looks like its ready to be shipped and donated to the kulluminati fund
- mazda915
dam i want one !!! that cf hatch
how much is it
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
There was a groupbuy ages ago...I think there are only 10 or 11 out there right now, but not many can afford it
There are a total of THREE true carbon FRP hatchs in ON, including the one I have, and a few wrapped ones.
- fowljesse
I opted for the Fiberglass one that doesn't have the thin layer of Carbon Fiber, because it was cheaper, and I painted it, anyway. It has been in continuous use since the group buy. It saved about 70 pounds, with the Lexan instead of glass.
Flyer, is yours true carbon fiber, or fiberglass with a thin outer layer of carbon fiber, like the rest of them?
Same group buy bro :p
- kulluminati777
70lbs?!?!?! That is alot! I wish the hatch would hold the MS wing then I would really want one!!
- Josh
There is a thread on here somewhere about weight savings and what each part of your car weighs. I thought the OE hatch with glass only weighed about 60-68lbs in total... I thought that with the CF hatch and lexan it was only like a 30 or 40 lb savings over OE?
I would love a cf hatch my only thing is under heavy cornering the rear is already light. Heck I keep 100lbs of tools in the trunk all the time anyways. and When I take them out it is very noticeable.
The OEM hatch can't be that light, if that's the case then I've become extremely weak.Josh wrote:T I thought the OE hatch with glass only weighed about 60-68lbs in total... I thought that with the CF hatch and lexan it was only like a 30 or 40 lb savings over OE?
- Josh
ok here you go found this
I was off by a few lbs in each direction. You will only be saving aprox 50 lbs.Mooneggs wrote:it will basically bring your hatch weight downso I'm not sure how much the lexan sheet actually weighs... once we get one we should weigh it to see exactly. Right now the hatch glass alone weighs 49 pounds...
Technical specs:
-OEM Hatch w/ glass: 77 lbs.
-OEM Hatch w/o glass: 28 lbs.
- fowljesse
Ah. Yes. I got my numbers confused. Unless those struts weigh 20lbs
- Josh
Well if you have a GS and pull the rear squirter bottle the spare tire and the jack that might equal 20 if the squirter is full of fluidfowljesse wrote:Ah. Yes. I got my numbers confused. Unless those struts weigh 20lbs
I've had a mold for a while now. I've made 3 so far and the last one is on my careasts1d3 wrote:Do you have any picture updates on your rad support mold?
i will be your first customer
I still need to work the surface and sand and trim the edges a little bit but it's all carbon.
It's hard to see surface flaws, maybe because of the lighting.
Dang! That turned out really good, how come the rad rubber mounts are not installed?
