ProjectB10 - 1993 Eunos Presso HI-XS
Re: ProjectB10 - 1993 Eunos Presso HI-XS Special Edition
maybe that interior does exist for the lhd model
in the bottom right corner there, looks like third gen interior
- bbunkerc397
Hey I want the oem rubber mats
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
- MrMazda92
I want those mats on the right side, in the middle!
WHOA 1990's neon artsy random paint brush marks FTFFW!!MrMazda92 wrote:I want those mats on the right side, in the middle!
lol its so retro I love it
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
- MrMazda92
Exactly man, I'd rock the hell out of those mats!!
I may do black diamond plate, shaped perfectly for the floor... Then throw rubber mats on top when passengers whine about it being hard.
Doesn't Mooneggs have something funkily similar for the floor mats?
- MrMazda92
He has the pinkish ones, they're similar, and I really wanted them!
You probably don't need to even guess if he was willing to part with them or not!
- projectB10
Couple of placeholder pictures for the Worklog. I need to write up an update. Its been a while.
Lovely car.
What kind of window visors are those? OEM? Aftermarket?
If you ever find another set of them, keep me in mind
- projectB10
LCA rear Bushings upgrade
Installed SuperPro SPF2417K double offset 46mm "shell" parts into 2 rear LCA fittings. Take a look at the attached link
http://www.superpro.com.au/?v=mazda-323 ... /999500245
You can purchase them online here....http://www.trademe.co.nz/motors/car-par ... 699695.htm
These are a "shell" fitting which requires that the old OEM 46mm fitting be pressed out so that the new poly bushing shell part can be pressed in. The SPF2417K option allows an offset of the OEM castor settings as a performance option;
http://www.superpro.com.au/why-superpro ... es-it-mean
I used a spare set of OEM fittings. The original parts were unmolested 21 year old bits and were removed from a road worthy JDM Eunos Presso car over the weekend. Amazing original condition once they were cleaned up. Looked like they were manufactured yesterday once they were cleaned up. Not bad Mazda OEM quality given the original bushings had completed about 316K kilometres. The bushing them selves had failed an MOT test here so decided to put them to a better use,
Bit of an effort required to get the original shells "moving" but once the "stickion" had been over come it was an easy job to remove them with a Ball joint removal tool. Not fitted up to project car yet but that's another easy job.
- projectB10
15mm Wheel 1993 Eunos Presso HI-XS Special Edition
+40 offset wheels (tyres 215x45.17) with 15mm spacers.
To my eye 15mm is perfect for the front but probably 12mm or even 10mm would be better for the rear. The
- projectB10
New purchase.
Now to see to clean it up and see if it can be made to fit....
- projectB10
Sorry SuperK missed your post. The visors are Mazda OEM as far as I can determine. They are (should say were) a reasonably common accessory fitted to the second hand Jap Import Presso/AZ3 we got here in NZ. I think I have another set sitting in the shed. Lots of gear all stuffed away. I will take a look this weekend.SuperK wrote:Lovely car.
Chris
- projectB10
All done
- WhiteFinish
Didn't know Presso's came without an armrest.
Love the gearknob btw.
