Hello friends, someone show me any online store to buy full kit Front Door Seals for an MX-3.
All suggestions are welcome.
thanks.
[WTB] OEM Door Seals MX-3
- MrMazda92
Re: [WTB] OEM Door Seals MX-3
- DEMBOU
Thanks friend, you will have the part number of the right and left?MrMazda92 wrote:http://onlinemazdaparts.com/ is your best bet...
Consider yourself warned, they won't come cheap.
- mitmaks
- MrMazda92
I have a passenger side one in decent shape btw, I forgot about that... If you can ship it, it'll come with a free door!
It's got a decent sized dent in it, so I replaced the entire door.
- DEMBOU
Ok thanks friend,
- MrMazda92
I'll try and remove the seal... You need the one that goes all around the door correct? The one that separates the door and the body of the car.
- DEMBOU
Yes, only need that seal .... thanks friend, I pay the shipping to 444 Brickell Ave Suite # 53-51114 Miami, FL 33131 U.S.MrMazda92 wrote:I'll try and remove the seal... You need the one that goes all around the door correct? The one that separates the door and the body of the car.
