KLZE Throttle Body + Cable.
If anyone is willing to ship to the UK for us?
Owner of the UK MX3 site.
- diezzel
Re: KLZE Throttle Body + Cable.
What is the number on the throttle body ? What cable ?
Trying to find out for you Diezzel, if anyone knows on here, can they post the info?
- MrMazda92
KL31 for Straightneck, I believe?
KL47 for Millenia, which I assume is what you'll be using.
If you're using the straightneck, a KL01 will work just as well, with some minor coolant rerouting(buy 2 slightly longer hoses and it's golden)
Yeah it's the curved neck one I have, so thats the Millenia one.
Could the stock K8 one be used? or is that what you mean by the KL01 ?
- MrMazda92
All of them will bolt up, but the K801 utilizes a 55mm bore, and all of the KLs use a 60mm bore. You would have reduced air flow potential, but it would get the car on the road.
The KL01 is for the KLDE, but would also bolt up, however the curveneck is different from the other intakes, it actually mounts nearly flush with the bore of the Throttle body, and the KL47 is an almost perfect fit.
I would hold out for the KL47, but if you need to get it on the road any should work for now.
MrMazda92, many thanks for the replies.. I'm in no rush so anyone have a spare KL47 for sale.
- diezzel
Just seeing if anybody knows the difference between a kl47 and a kl68 throttle body ? I can't see any difference . . There the same bore size . ???? Thanks
- MrMazda92
No problem Lori, I'm here to help.
diezzel, The difference will never be bore, but is most likely the IAC configuration. Maybe the idle airflow pathways are different too? Or even coolant routing for that matter. It would most likely work as well as any other, especially since it's a curveneck.
- diezzel
What does the kl47 usually go for in price ?? If anybody knows . Thanks
- MrMazda92
I typically see throttle bodies go for between $20-45, depending... Much higher than that and they sit for months without selling.
- diezzel
You looking for some seatbelt bracket ????
- MrMazda92
crazycanadian is sending me pictures of some, if his work then he's first on the list... If not, I'll let you know!
I am as well, passenger side jdm belt extender.diezzel wrote:You looking for some seatbelt bracket ????
