radio not working....at all
- 93DrunkMx3r
Alright, in the latest car development my radio doesnt work...at all. Now i checked the fuses and they are fine. Pulled the radio out, and everything is tied together. What are the 2 red wires coming from the car to the radio...those are the only two not attached to anything....everything else is taped together but the radio doesnt power on.
Re: radio not working....at all
This happened to me a few times after I had taken the central column plastics apart( bit that covers the gearstick)
because I forget to attach the earth ring back on for the stereo.
- 93DrunkMx3r
ok...so i figured out that the last person to hook the radio up was a moron....thought i had everything sorted but when i turn my headlights on...the radio loses power...what theeee heck is going on?
Did you check the ground wire?
93 GS SE - Raspberry metallic. K8 - 2 1/4in exhaust w/Magnaflow street series muffler, Custom intake, Kyb Gr2's w/Apex springs, Full kenwood audio - SOLD
tighten all your grounds. clean and retighten your negative battery terminal.
- Take the radio out
- Pop your hood
- Tie the red and yellow wires together and connect them to the Positive
- Connect the black to any Ground or Negative post on the battery.
- Tell us if it still doesn't work...
- Pop your hood
- 93DrunkMx3r
sorry for the delayed response but the ground looks good at the battery and at the deck...i will check my other grounds n let you guys know.
