Actual 5-lug swap info.
Evo_Spec
Post by Evo_Spec »
not sure if this was posted here yet or not but the pile did an actual "how to:" for us! (well, everyone)
http://www.clubprotege.com/forum/showth ... MX3-Escort
BornSticky
Re: Actual 5-lug swap info.
Post by BornSticky »
so do the brakes have to be swapped as well obviously the rotors do but pads and calipers?
im really wanting to do this cause my rims are starting to get pretty ugly looking and have a 16" pair of rims i was gonna sell that were 5 lug but if this conversion actually works! 8)
#5389 to join MX-3.com
Evo_Spec
Post by Evo_Spec »
BornSticky wrote:so do the brakes have to be swapped as well obviously the rotors do but pads and calipers?
i actually have no idea but if i was to guess you use the rotors and calipers/pads from the donor since he says:
The Pile wrote:6. Install brakes. Stock brake lines work.
meaning the stock line will go to the new caliper, no?
AaronTietje
Post by AaronTietje »
Here are some actual pics of the probe front hub modified to fit our struts next to my old mx-3 hub.
I also have two other sets of brackets to mount these calipers to the probe hubs....
BornSticky
Hmmmm I donno if I wanna bleed my brakes just for another lug.
MrMazda92
Post by MrMazda92 »
How about for Mazda6 big brakes? :wink: 5 lug potential is pretty badass...
Evo_Spec
Post by Evo_Spec »
BornSticky wrote:Hmmmm I donno if I wanna bleed my brakes just for another lug.
lol, bleeding your brakes is super easy IMO
unless you have SS lines, just clamp the brake line so the fluid doesn't come out, then you have less to bleed
marcdh
Post by marcdh »
Or live in Europe and just bolt on the 323F BA parts... For once a cheaper option in the UK :laugh:
View Worklog
Mi|<E
Post by Mi|<E »
Do not do this, get a vacuum bleeder and do it properly. Brakes aren't one of those things to not do correctly.
Evo_Spec
Post by Evo_Spec »
worked fine for me :shrug:
DeadMaker
Post by DeadMaker »
marcdh wrote:Or live in Europe and just bolt on the 323F BA parts... For once a cheaper option in the UK :laugh:
But still it's rare part this model..
Black Mazda Mx3 Rs 1997 B6DE
