Get your timing belt on correctly the first try
- Ryan
Re: Get your timing belt on correctly the first try
Yes! I know what you mean.
I also agree that 170º CW is the correct spot. So a little to the right of 180º.
I have an important question about all this. When i'm doing the Timimg belt must i replace the pullys and tensioner or just the tensioner or just the belt? i've been told by everyone something different and now i'm just worried, trying to build a Mx3 and everyone has an opinion.
- Ryan
That is up to you.
Spin the pullies by hand, if they sound dry at all, I personally would replace them, because I like a quiet, non bearing noise idle. If they feel a bit stiff, but quiet, that is normal, and it is probably pretty new.
On the other hand, I've never heard of one failing. Like most bearings, they get louder and louder and louder until you can't handle it, before they get louder yet and then fail.
- WhiteFinish
I can't believe I looked over the topic.
Thanks for the write up Ryan !
- MrMazda92
I like how nobody ever replied to this, and I only just now noticed it! I figured Dan would have been here already, honestly.wytbishop wrote:My wife touched a wrench once...I accidentally left it on the kitchen counter.
I used to leave tools in the kitchen sink, soaking before being towel-dried and sitting in the sun. My ex hated me for it, she liked a clean kitchen, and I like clean tools.
- ruthless_mx3
resurrected from the dead....
THIS NEEDS TO BE STICKIED!!!!
I still don't know why this has never been made a sticky in the v6 faq. This here is by far the absolute best writeup on setting the timing belt. Please sticky this so I never have to search for it again and so others can take advantage of the benefits of this write-up.
Thanks
Thanks
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
But it is stickied?
- kulluminati777
Hes an old school member so he still uses the FAQ i think he wanted it there
- ruthless_mx3
oh wow i feel like a major idiot. I've looked at the v6 forum how many times and i've not noticed it at the very top first thing on the list. durrrrrp
Thanks for this, did mine on the weekend on my KLZE.
Owner of the UK MX3 site.
just a bump for a thank you, saved me a bunch of time on my 4th motor swap
This might sound like a silly question but which direction do you count from or does it matter?
Great post !
