want to do the Klze swap
hey i have a 1993 gs with the k8 i want to know how to swap the klze in i know u have to use the mx6 tranny and need the kl31 or kl36 do u have to swap any cannectors what injectors do i use what wheel axels do i use the mx3 ones or the mx6 does the engine harnes from the k8 match up. any help is appreciated thanks
Re: want to do the Klze swap
You've already got at least one thing wrong. You need to do some reading. You're not going to get a lot of help if you don't show that you can at least get the basics figured out on your own.
Man, those are very, very, very basic questions. You need to do a little bit of research. That those answers are as plentify as my post count, so try a little bit. As SuperK pointed out the FAQ is a very good place to start, and the Search is your friend....Gs kid wrote: - i know u have to use the mx6 tranny
- do u have to swap any cannectors what injectors
- do i use what wheel axels do i use the mx3 ones or the mx6
- does the engine harnes from the k8 match up
you dont 'HAVE' to use the mx6 transmission
i have the MX3 Transmission with my KLZE but most people will switch there 5th gear to the 626 or the mx6 or probe gear set because of the longer ratio that allows a better highway fuel mileage.
also the axles will depend on what transmission you are using!
as for connectors etc.. Research --- the search function works well ---
also there is a UK.MX3 page that has good info aswell about the swap .
good luck man keep us posted on what steps your going with
Terry
Terry
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
Previous rides
No, makes no difference if your using an Mx-3, Mx-6, 626 or Probe trans, you use the Mx-3 axles. The only time you use other axles is if you get a JDM LSD trans, that's it!whitete wrote:also the axles will depend on what transmission you are using!
Helpful hint #1...beware engine swap advice from members with 53 posts.
i dont see anything wrong with anything that guy said. except that most members dont do a 5th gear swap, but it is still a good idea...wytbishop wrote:Helpful hint #1...beware engine swap advice from members with 53 posts.
Except that he thinks that the transmission you use will dictate what axels you use...which Mike pointed out is not the case.mikeinaus wrote:i dont see anything wrong with anything that guy said. except that most members dont do a 5th gear swap, but it is still a good idea...wytbishop wrote:Helpful hint #1...beware engine swap advice from members with 53 posts.
Listen to the FAQ's
when they're calling for you.
Listen to the FAQ's
there's nothing else you can do.
I don't know where you're going
and I don't know why,
but listen to the FAQ's
before you tell your mx-3 goodbye.
Listen to the FAQ's
SuperK wrote:Listen to the FAQ's
Listen to the FAQ's
sorry guys they are right about all axles are the same minus the JDM LSD transmission.
and i thought most here did do the 5th gear swap - sorry -
and i need to make more helpful hints and tips and post more topics that are meaningful to make my post count higher - over 53 - mabey if i had over 1000 id know more about the mx3 .
ive owned 5 mx3's so far and swaped out 3 of the k8 engines for KLDE's
and my current DD was daninskis red KLZE that he swaped
wytbishop (sorry) for not being so helpful - i mean thats why were here
and Nd4SpdSe
thank you for the clarification about the axles i dont want to give false info to other memebers . just it was to my memory that there were two types of axles offered not just stage 1 2 3 etc..
and Nd4SpdSe
Previous rides
Previous rides
whitete, the best way to up your post count is to post animated smileys singing/dancing/etc
It's very helpful. buahahaha, what, me trying to cause trouble? nooooooooooo!
Previous rides
Previous rides
No problem. You can get Stage-whatever axles for whatever cars you have, it depends on how much power you're putting down. If your OEM axles are in good shape, they'll have no problem using your originals....unless your running a turbo or have extremely heavy rims (ala Trevor). Check with your local parts supplier, some even come with a lifetime warrantywhitete wrote:and Nd4SpdSe
