Did some searching around on here to see if from a near stock height if there would be a great deal of air potentionally getting trapped there. Went on reading people having different thoughts on if it would be worth it to make/invest in a type of diffuser. Some were saying unless your an inch or so away from the ground that would be where a noticeable effect would occur.
So looking at many peoples worklogs and what they have done, plus i've noticed some people with hondas would cut holes in their bumpers i tried to put some ideas together. Honda having a much bigger aftermarket/ following then MX-3's, that maybe theres been more research into that particular area, maybe not we've all seen the horrible ideas Honda guys come up with
I'm not about to go drilling holes everywhere and what not but i was looking at the Euro front bumper and the holes for the foglights and thought what if i took either ports from a sub box, cut out the holes and insert the ports for a cleaner look. Thinking it might not work with the ports and the curve on the bumper to use a type of weatherstripping to clean it up.
Took a quick look on ebay and found http://www.ebay.com/itm/Universal-Rear- ... c6&vxp=mtr maybe that would work for what i have in mind. I'm probably just overthinking things like i always do. But since without a windtunnel test for any of the ideas its basically just trying and take a similar idea and convert it over. Now that i've rambled on for a while i'd like to hear some ideas on if the holes in the bumper would make a difference and if a diffuser would be a good way around the irreversible holes, or if thats more cosmetic that anything. Thanks for the input!
