I couldn't find it that quickly, perhaps somebody can help me out.
The nut in the hub that bolts the axle. How much NM or torque should it be fastend?
Axle nut torque
- WhiteFinish
- mitmaks
Re: Axle nut torque
- WhiteFinish
Re: Axle nut torque
Thats quick
But how do I read it ?
235-319
24.0-32.5
174-235
What is what ? NM, Ft lb inch ?
235-319
24.0-32.5
174-235
Re: Axle nut torque
174-235 ft lbs. You can read it at the bottom rh side of the figure.
- WhiteFinish
Re: Axle nut torque
Right... I can continue again.
Re: Axle nut torque
lmao, i cant get mine off.. tried heating it up, using penetrant. broke two ratchets and two breaker bar attachments. waiting on a proper socket. Glad to know what to torque it back to.
- MrMazda92
Re: Axle nut torque
I use a 1/2" Craftsman breaker bar, with a thick a-- cheater pipe and someone holding the brakes. Couldn't hurt to give it a few taps with an impact gun first, no? Penetrant is a good idea too.
