Car is a 1992 mazda mx3 gs 5 speed(engine all stock, even the filter).
SuperK wrote:spray some brake cleaner around the intake manifold and see if it bubbles around the edges of hte manifold, that'll tell you whether you got a leak on them or not.
Sleeper6 wrote:I'ld put money on a disconnected vacuum line behind the manifold or at your intake, mainly if you can keep it running with throttle you have unmetered air causing it to die.
SuperK wrote:brake cleaner... carb cleaner... whatever's flammable >: D
Sleeper6 wrote:Why did you pull your injectors off the manifold btw? Im pretty sure I swapped mainfolds without removing those before
