Just checking if anyone found a better, non plastic rad? I know it is not required in most cases, but I want one just the same. I am looking for a full size (no civic half rad) that will fill the existing spot of the OE rad (give or take as I am sure it will not be an MX3 rad). I have doubled the HP rating of my B6, and have read it's a good idea to upgrade the cooling system, so that's the plan.
Just checking if anyone else has been searching around as much as I have. If it comes to it, I will bug the h3ll out of Mishimoto to see what will be a close fit.
Thanx in advance.
Anyone found a good rad?
- RS_OBD'oh_2
- Ryan
Re: Anyone found a good rad?
I bet the B6 does not hit half of its heat capacity, so I think you're fine with stock.
Daninski seems to swear by radiators.com
Love those guys, over nite shipping too.
- Josh
BAM! http://performanceradiator.com/ BAM!
These guys sell an OE rad with METAL caps vs the dumb plastic caps.
tbondo
I found this radiator by doing a google search. Never dealt with them but it's an option for you.
http://www.genesisautoparts.com/all_alu ... v6_110.htm
