Mi|<e - 94 GS BPT dyno tuned
Re: Mi|<e - 94 RS BPT dyno tuned
I suspect the oil pump death caused the initial wear and its just been getting worse over
time.
I had 10 cylinders in my GS today!
So the wear is on the skirts and the cylinder walls, I have yet to bust out the vernier and see
if the pistons are hooped. Piston #3 took the worst beating:
The crank bearings and the crank took no damage whatsoever. It is indeed made of invincible.
Bag and tag your junk, it makes life easier.
There is my turbo BP.
time.
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
1994 MX-3 RS
- Evo_Spec
guess i need to take your kia tranny and LSD =D
so whats the plan? another rebuild?
Bearings, no!
1994 MX-3 RS
- Ryan
*shudder*
I had enough nightmares about one set of bearings looking like that...
Seems like you've been having a bad luck streak.... or just a set of opportunities disguised as bad luck
This is from when the oil pump failed back almost two years ago, I
checked the main bearings which are fine but didn't catch the rod
bearings. Im going to shim my oil pump up a bit and live with higher
oil pressure. Heard 3 1/4" SS washers do the trick.
1994 MX-3 RS
Fresh head is fresh with reconditioned BP26 turbo cams
1994 MX-3 RS
- Tavman_1213
It looks awesome!! Hopefully I get to see this car in person instead of just photos!!
93 White RS- BPT Built not bought!!
Worklog: viewtopic.php?f=46&t=78988
- Evo_Spec
+1Tavman_1213 wrote:It looks awesome!! Hopefully I get to see this car in person instead of just photos!!
so glad to see it's getting put back together.
- jeffs93toy
This is a killer worklog. Glad to see it being continued as Im gonna use this as a what to do to my new bp as far as the rebuilding goes.
Awsome work sir, please keep it up.
My feedback viewtopic.php?f=37&t=78944
My worklog viewtopic.php?f=46&t=78228
My want to buy viewtopic.php?f=48&t=79033
Finally got some new supertech piston rings to re ring the pistons, thanks goes to
RS_OBD'oh_2 for these:
I had to borrow a piston ring gapping tool, its just a hand crank stone on a platform:
So went the tedious chore of gapping piston rings again... At least this time I know
enough that it went fairly smoothly. The bottom rings were all gapped how I wanted
them without having to grind which was nice.
Even though the pistons had some skirt scratching it came out rather nicely with
some sandpaper and elbow grease:
Installed the pistons:
And finally lubed the snot out of the rotating assembly pieces:
Pistons installed, yey.
Also have a new headgasket, look at the engine code on it:
All I need to do is clean up the engine bay how I want it and reassembly of the
engine will be soon. I have a tuning date in April so there is a deadline.
Also rumor has it that I might get myself a subaru...
1994 MX-3 RS
- Evo_Spec
i missed your work logs so much, i forgot how many pictures you take =)
it's nice to see there was no damage too major that you couldn't fix.
is the BP26 head gasket any different? i guess it's made to handle boost
everyone's getting Subaru's lately XD
Ive done more work on the car this weekend.
The worst part was lifting the block up into the transmission from below. When I do this
next im going to take out the entire engine on my engine hoist.
Looks pretty clean.
Had to pick up ARP moly lube for assembly, can't torque them as tight without it...
The entire valve cover was cleaned out and the oil traps were resealed.
Used the leftover moly on the cam lobes, no such thing as over lubing.
Called it a day here.
On a more crappy note the turbo exducer was ceramic and had a chipped fin so
the entire turbo is being rebuilt. New engine new turbo.
Looks pretty clean.
1994 MX-3 RS
- Calg_93GS
TOO MUCH LUBE... lol, looks good bud, shoulda givin me a call, was bored most of the day
