Source for upper & lower rubber spring seat
I ordered some replacement struts along with everything else except the rubber seats the coils sit on. No auto part place has them locally and I can't find any online either. I only have the uppers and the lower weren't even on the vehicle. Anybody know where to order some?
Re: Source for upper & lower rubber spring seat
i dont think there are bottom seats. try calling mazda...
- jeffs93toy
I just took mine apart, and there are no bottom rubbers.
My feedback viewtopic.php?f=37&t=78944
My worklog viewtopic.php?f=46&t=78228
My want to buy viewtopic.php?f=48&t=79033
- Evo_Spec
mine had them, actually i might have pulled them off the ZX2 struts in the junkyard....i don't remember but i have some.
you can see them here
*edit* actually now that i looked at some photo's, i don't think i had front ones.....
- im2bad4ya
you can get them, but for whatever reason, the part number doesn't link to our cars (ie. won't say "fits MX3"). Check out my worklog under the suspension section for the right part #
*edit*
If I remember correctly, the front suspension only has upper spring seats, rear suspension has only lower spring seats, either way, check out my worklog, that should be helpful
*edit*
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
Thank you, that helps tremendously.
I haven't taken the rear ones out yet but the front did not push out at all when I pushed the shock piston in. I can't wait to get it all back together.
- Evo_Spec
i think your right and the rear doesn't have the upper seat because it's part of the mountim2bad4ya wrote:If I remember correctly, the front suspension only has upper spring seats, rear suspension has only lower spring seats
I'm working on a similar project...
Rear upper is part of the mount, and comes with a new mount.
You can get the rear lower seat from partsgeek but search for ford escort zx2 coil spring insulator. They also have a set for front lower.
The front upper seems a trick, through them its only available with the upper spring seat.
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
