[FS] MX-3_4EVR'S PART OUT! !!!!!
- mx-3_4evr
Re: [FS] MX-3_4EVR'S PART OUT! DIRT CHEAP!!!!!!!!!!
pics are up with updates. I'm more at clubprotege.com, so if you want quick answer go there. I check this site once a day, not that I don't like it here
- Ryan
You should answer my PM about the MS then
How many ignition and injector drivers?
- MrMazda92
Evo_Spec, you will need MS to make coilpacks work. I'll go Coil on Plug personally, it allows you to cut out some more weight and clean up the engine bay even more.
RS_OBD'oh_2,
It is sad to see another member selling, but he didn't come off as indecisive to me... We all try to encourage people to stay, if they're on the fence whether or not to sell, but this is completely different. He started out with "I'm getting rid of my MX-3 for good.", and "Guys all the parts that you have been dreaming of are right here, so buy my parts "
Nobody meant any offense, although courtesy does dictate we say at least something.
For that, I am sorry; I do still think what you said was a bit harsh.
OP, Please respond to my PM I'm curious about the quote.
RS_OBD'oh_2,
- Evo_Spec
cool thanks, i saw some people swap it over but never really paid attention to what they were running.MrMazda92 wrote:Evo_Spec, you will need MS to make coilpacks work. I'll go Coil on Plug personally, it allows you to cut out some more weight and clean up the engine bay even more.
- mx-3_4evr
No idea. I had it assembled and then I just got the settings for my car and ran it.Ryan wrote:You should answer my PM about the MS then
MrMazda92: I didn't mean it that way. I meant it for my wallet
- Ryan
Did you do any of the programming yourself? You could tell from that. You did wasted spark, so you were using two ignition drivers. Did you have one or two or three or four.... turned off?mx-3_4evr wrote:No idea. I had it assembled and then I just got the settings for my car and ran it.Ryan wrote:You should answer my PM about the MS then
Im going to pass on the belts, appreciate getting the quote for everything
- MrMazda92
Have the seat belts sold? If not, what all is included? I can have payment out monday night for these if I decide on them.
- mx-3_4evr
2 I think....Ryan wrote:Did you do any of the programming yourself? You could tell from that. You did wasted spark, so you were using two ignition drivers. Did you have one or two or three or four.... turned off?mx-3_4evr wrote:No idea. I had it assembled and then I just got the settings for my car and ran it.Ryan wrote:You should answer my PM about the MS then
- mx-3_4evr
No problem man! LKM if you need anything elseSleeper6 wrote:Im going to pass on the belts, appreciate getting the quote for everything
- Ryan
Is that two turned off? Or you only had 2?
I kinda need to know this before buying... if you only had two ignition drivers the unit is useless to me.
- mx-3_4evr
Front rear seat belts, pillar covers, and top panels behind the front doorsMrMazda92 wrote:Have the seat belts sold? If not, what all is included? I can have payment out monday night for these if I decide on them.
- mx-3_4evr
How do I check that? I thought you went under settings and changed how many cylinders you wanted to fire under ignition on the basic settingsRyan wrote:Is that two turned off? Or you only had 2?
- MrMazda92
So everything I'll be needing then? Awesome.
I'll PM you my email for pictures, if they look as great as I'm hoping, you sir will have payment on Monday night.
- mx-3_4evr
Sounds good.MrMazda92 wrote:So everything I'll be needing then? Awesome.
