ok need help plz
- FastFlaMx3
ok need help plz
ok finally got motor running right after all this time and now i got fluid driping off clutch pedle and i have no clucth peadle when car is running shut off car and i get alil bit of peadle i couldnt get car into first sitting at light today what can this be im about so sell this car damm i put almost 4k into this car .
- DeadMaker
Re: ok need help plz
How the clutch will work if there is no fluid?Check your vacuum hoses for the leak..
Black Mazda Mx3 Rs 1997 B6DE
- Inodoro Pereyra
Check your connections. If the nuts are tight, you need a new clutch master cylinder. And make sure you bleed the thing properly.
Diogenes of Sinope.
Diogenes of Sinope.
- FastFlaMx3
ok so it leaking fuid out of pedle i just went and bought new master cyld and slave im just going to change these and see what happensthere is a puddle of brake fuid in the driver floor board and it leaking out of the clutch peadle
- Ryan
Its a pedal.
leaking from the pedal means your master cylinder is toast.
- FastFlaMx3
well heres what i found old pone on left
![Image](http://i101.photobucket.com/albums/m57/Ralph1575/100_42941.jpg)
- FastFlaMx3
ok got new master in clutch still got alil play but that can be adjusted from the pin on the pedle right? going to try to drive it to work will let u know how it feels tonight
