As much as I've wanted to finish this, I simply don't have the time or money to go any further and it's too sad to watch this car sit in my garage not being completed. I'd like to sell the entire car plus all accessories/parts not attached to the vehicle as a package deal. I'm in the Charlotte, NC area. I've kept a running list as well as most receipts of the $12,000 in parts I've purchased. I will sell the car and everything I have for $3500. It will have to be picked up though because I do not have it running yet. You can see pics of the car on my car domain page:
http://www.cardomain.com/ride/800979/1993-mazda-mx-3
Here is my list of parts I purchased for my MX-3 along with the price I paid and where I got it:
Engine / Drivetrain
1.8L BP Turbo Engine $1,250.00 CorkSport
ACT Street Performance Clutch Kit $414.00 CorkSport
G25M-R Transmission (97 Kia Sephia GS) $350.00 Junkyard
MSD 6AL Ignition $195.00 eBay
MSD Blaster 2 Coil $36.00 eBay
MSD Tach Adapter 8910 $35.00 eBay
MSD Coil Bracket $5.00 eBay
450CC Denso Fuel Injectors (2nd Gen) $113.00 eBay
Walboro 255lph HP Fuel Pump $95.00 eBay
CorkSport Power Series Intercooler $250.00 CorkSport
SRD engine mount member bushings $54.00 CorkSport
Alternator (94 Protégé) $35.00 Junkyard
Driver side axle (97 Kia Sephia GS) $90.00 Advance Auto
Passenger side axle (97 Kia Sephia GS) $90.00 Advance Auto
Intermediate Shaft (jack-shalf, 97 Kia Sephia) $37.00 Junkyard
Transaxle Mounts (97 Kia Sephia) $27.00 Junkyard
CorkSport SS Clutch line (clear) $18.00 CorkSport
Summit Racing Battery Relocation Kit $85.00 ebay
Engine Lift & Lifting Chain $165.00 Pep Boys
Clutch Slave Cylinder (Protégé) $35.00 Advance Auto
Pacesetter Quik-Shift shifter $95.00 CorkSport
Standards O.E.M. Flywheel $51.00 Advance Auto
Optima Yellow-Top Battery $188.00 Advance Auto
NGK Iridium Spark Plugs $28.00 Advance Auto
Magnecor 8.5mm Race Wires $83.00 CorkSport
Silver Oil Catch Can Kit $31.00 eBay
Specre Vacuum Hose Kit $16.00 AutoZone
Spectre Braided Hose Sleeve Kit $50.00 AutoZone
Spectre Wire Seperators $7.00 AutoZone
DSM Resistor box w/ Honda injector clips $32.00 eBay
Throttle Body from Manual Trans (94 Protégé) $25.00 Junkyard
APC Breather Filter $9.00 Advance Auto
Wire Loom 3ft-blue $4.00 Advance Auto
Wire Ties - black $3.00 Advance Auto
Spade Connectors $16.00 Advance Auto
10ohm Resistor for DSM Injectors (x4) $5.00 RadioShack
Radiator Classic OEM Radiator $167.00 eBay
Intercooler Pipe Kit $350.00 eBay
CorkSport Power Series Down Pipe $290.00 CorkSport
***Coolant Temp Switch $26.00 Advance Auto
***Oil Pressure Switch $9.00 Advance Auto
***Crank Pulley Bolts (4) $14.00 Mazda
***Oil Pan Gasket $9.00 Advance Auto
***Manifold Gasket Sets $35.00 Advance Auto
***Fuel Filter $16.00 Advance Auto
***Valve Cover Gasket $12.00 Advance Auto
***Ignition Cap & Rotor $17.00 Advance Auto
***PCV Valve $3.00 Advance Auto
***Thermostat & Gasket $8.00 Advance Auto
***Water Pump $48.00 Advance Auto
***Timing Idler / Tensioner Kit $91.00 Advance Auto
***Timing Belt $30.00 Advance Auto
***V-Belt $17.00 Advance Auto
***Accessory Belt $19.00 Advance Auto
***Mobil 1 Tri-Synthetic 5W-30 $25.00 Advance Auto
***Mobil 1 Oil Filter $10.00 Advance Auto
***Throttle Body Gasket $2.00 Advance Auto
***Motor Mount Bolts (2) $16.00 Mazda
***Jack-Shalf mounting bolts (3) $26.00 Mazda
Suspension / Brakes
SRD Suspension arm bushings $106.00 CorkSport
SRD shifter extension bushing $39.00 CorkSport
CorkSport SS Brake Line Kit (rear drum) $89.00 CorkSport
KVR Carbon Fiber Brake Pads $45.00 CorkSport
KVR Cross Drilled Rotors (CAD plated) $173.00 CorkSport
SRD Bronze Oil shifter bushings $38.00 CorkSport
R-active front strut bar $45.00 eBay
R-active rear strut bar $65.00 CarDomain
Ball Joints (mx-3) $111.00 Advance Auto
Tie-Rod Ends (mx-3) $21.00 Advance Auto
Rear Brake Drums (2) (mx-3) $84.00 Advance Auto
Rear Brake Shoes (4) (mx-3) $27.00 Advance Auto
Axle Nuts (Protégé) $11.00 Advance Auto
Brake Calipers (2) (mx-3) $118.00 Advance Auto
G2 Brake Paint (blue) $35.00 eBay
CorkSport Urethane Exhaust Hanger Kit $56.00 CorkSport
Control Arm Through Bolt $8.50 Mazda
OEM Front Sway Bar End-Links $61.00 eBay
Goodyear Eagle F1 GS-D3 205/40R17 Tires $811.00 Discount Tire
Interior
A-pillar gauge pod $65.00 mx-3.com
Folia-tec interior car paint $125.00 eBay
momo king shift knob $45.00 eBay
momo steering wheel $185.00 eBay
momo pedals $65.00 ebay
reverse glow gauges $45.00 eBay
aluminum guage bezel $15.00 eBay
momo shift boot kit $30.00 eBay
momo steering wheel spacer $45.00 eBay
quick-release steering wheel adapter $35.00 eBay
Otto-R Racing Seats (2) $300.00 eBay
Ralli-art 4-point racing harnesses (2) $50.00 eBay
New MX-3 Silver Molded Carpet $195.00 1Aauto.com
Under-carpet padding (sound dampening) $35.00 JC Whitney
ALU Chrome Manual Window Handles (2) $33.00 Pakfeifer Tuning
Kill-Switch $12.00 Pakfeifer Tuning
Ignition Switch / Push-Start Panel $26.00 Pakfeifer Tuning
Autometer Gauge Panel - 3 Hole $21.00 eBay
Autometer #7516 Fuel Level Gauge $60.00 eBay
Autometer #7527 Oil Pressure Gauge $83.00 eBay
Autometer #7575 Air/Fuel Ratio Gauge $78.00 eBay
Autometer #7544 Pyrometer Gauge $166.00 eBay
Autometer #7592 Voltmeter Gauge $60.00 eBay
Autometer #3262 Fuel Level Sender $40.00 eBay
Autometer #7507 Boost/Vac Gauge $76.00 eBay
OEM Style Hatch Cover $80.00 evilyeti.com
Keypad Ignition Immobilizer $52.00 eBay
Fuses & Fuse Holders for gauges $21.00 Advance Auto
5-pin Relay for Keyless Ignition x 2 $24.00 Advance Auto
Various electrical connectors, etc $33.00 Advance Auto
Exterior
JDM MX-3 eyelids $35.00 eBay
Altezza Black Taillights $185.00 eBay
Konig Unknown 17"x7" Wheels $635.00 eBay
Audio
Rockford Fosgate P450.4 Amplifier $175.00 eBay
Rockford Fosgate P325.1 Amplifier $146.00 eBay
Rockford Fosgate 12" Subwoofers (2) $0.00 friend
Pioneer DEH-5900iB Headunit $198.00 Best-Buy
Dynamat eXtreme Door Kit $30.00 eBay
FatMat 100 square feet $95.00 eBay
Pioneer TS-A6991r 6x9" speakers (4) $156.00 eBay
Pioneer TS-A1371r 5.25" speakers (4) $108.00 eBay
Tsunami AMP48Cap amp Kit $165.00 eBay
XTC 6x9" speaker baffles (4) $21.00 Crutchfield
12' 3rd RCA cable $8.00 Wal*Mart
Black Subwoofer Box carpet - 3 yards $32.00 Crutchfield
MDF Board $26.00 Lowe's
GRAND TOTAL: $12,320.50
[FS] 93 BP-Turbo project car ~80% complete
- RS_OBD'oh_2
Re: [FS] 93 BP-Turbo project car ~80% complete
aww man, you are soo close. I know there is a wall a builder can hit. You can see the light at the end of the tunnel, but you don't know how to go on. I've seen it with supra owners as well as myself. But I can tell you this; you will never drive a car as good as the one your built to your specs. And you will never have that level of pride with any other car.
There are many people in my city whom have bought jdm imports. They think they own the streets in cars someone else has built. They will never know how to build a car up from 100hp to something that can whoop a corvette. I urge you to stick with it, you'll never know what it feels like. I wish I can put it into words, but I, myself am still on that very path, an can offer you no closeure.
No matter what you decide, I wish you the best.
Thanks. I'd love to finish it, but I just don't have the money to invest into it anymore. Things are really tight right now and I'm having to part with things that I don't "need." Ugh!
RS_OBD'oh_2 - Ihad to write that down....
SuperStealth - Sorry to hear. I fear someday I will have to part with giving mine up. I wish you the best on your sell.
___________________
Black '92 GS [Project De-t Started!] [The spoiled one]
Green '95 1.6 [Daily][The jealous one...SOLD]
White '07 Mazda 3 GT [The pretty one]
[What can you say, I have a fetish for 3's]
![Image](http://i724.photobucket.com/albums/ww241/patmx3/babies-3-1.jpg)
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
