seatbelt switch
myfirstmazda
seatbelt switch
I know it's a dumb question, but where is it located? My search didn't help much. My seatbelt likes to click back and forth when you open the door sometimes, it seems to be worse when the car's wet.
myfirstmazda
Re: seatbelt switch
Bueller?
Bueller?
Bueller?
Been a week... no replies?
Bueller?
Bueller?
- Evo_Spec
Re: seatbelt switch
since i don't have an auto seatbelt and never even seen one my guess is that it just goes off the door switch which is located a little under where the door latch is on the car
- Evo_Spec
Re: seatbelt switch
or....i was kind of wrong, you can see it here in this picture, its just above the front of the mini side skirt.
obviously you'll want the driver side switch which is located in the same spot
- muttpower
Re: seatbelt switch
Chronic issue with the MX3 auto seatbelts...that's why I swapped mine to manual....but anyways, there's a recall on em...get it replace for free...
1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
myfirstmazda
Re: seatbelt switch
I had the cable done last year because it was jammed up. yes, it was done for free on the recall, but my understanding is that the switch is only covered for 12 years, so who knows? I'd just like to fix the switch myself anyway... are they expensive?
myfirstmazda
Re: seatbelt switch
are you talking down in the bottom rear corner?Evo_Spec wrote:or....i was kind of wrong, you can see it here in this picture, its just above the front of the mini side skirt.
- Evo_Spec
Re: seatbelt switch
yup, but i forgot that like muttpower said, there was a recall on the auto seat belts so if you bring it into mazda they will fix it for you, free of charge (or make sure they don't charge you)myfirstmazda wrote:are you talking down in the bottom rear corner?Evo_Spec wrote:or....i was kind of wrong, you can see it here in this picture, its just above the front of the mini side skirt.
myfirstmazda
Re: seatbelt switch
ok, here's the update: the switch in the corner of the door frame only operates the dome light. the one for the seatbelt is somewhere inside the door, but it's connected to the latch mechanism. I just sprayed some Liquid Wrench in the latch and so far it seems to have cleared up. I decided to attack it today at break time, so it's only been a few hours, but so far, so good. thought I'd post so others could find the info.
Re: seatbelt switch
I know this post is a few months old but will mazda replace anyone free of charge? just got my car and both the seatbelt motors are broken/screwed up.Evo_Spec wrote:yup, but i forgot that like muttpower said, there was a recall on the auto seat belts so if you bring it into mazda they will fix it for you, free of charge (or make sure they don't charge you)myfirstmazda wrote:are you talking down in the bottom rear corner?Evo_Spec wrote:or....i was kind of wrong, you can see it here in this picture, its just above the front of the mini side skirt.
92' mx-3 GS
Re: seatbelt switch
I got mine done free of charge per the recall on my 1st mx-3 about 7 years ago it was a '92. If you just call local dealerships and ask they will let you know.
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
