92 mx3 gs IAC shot?
Re: 92 mx3 gs IAC shot?
If you can't find one he might have one. http://www.mx-3.com/phpBB3/viewtopic.ph ... 46#p580746
Ryan
Post by Ryan »
I STILL vote vac leak...
disagreement between VAF and O2's causes the ECM to choose the richest mixture.
haze
Post by haze »
thanks for all the feedback.
well i put off doing anything because i really dont have the cash and then as the weather warmed, my mileage was good enough that it got me to work all right for the time being.
last couple days i've noticed a deeper humming noise coming from the back, i kept thinking someone was mowing their lawn, but it was me all along.
today, i heard the noise quite apparently after starting it up. then 30 seconds down the road it started missing and sputtering.. then 30 seconds later it was barely moving along. if i gave it too much gas it would just cut off. if i lightly feathered it i could keep pissing along. i was just trying to get home. eventually it just got slower and slower and wouldn't rev at all. and just slowly came to a stop and then at a stop it stalled out.
i checked for codes and got nothing. as of now its not starting back up, just cranking.
a few months back i tried inspecting for vac leaks around the main accordian section by spraying water and lookin for bubbles. didnt find anything. not sure what else i need to check for that.
MrMazda92
Post by MrMazda92 »
If it's IAC related, unplug the POS. Let it warm up a little longer in cold weather starts, and you'll be golden.
