95 mx3 front hub/spindle/knuckle assembly
will a 92-93 knuckle work on a 95 as long as you use the ball joints from that year or does more stuff need to be changed out, like the tie rods, lower control arms, etc
- Ryan
Re: 95 mx3 front hub/spindle/knuckle assembly
you could use Probe knuckles if you wanted to use Probe struts.
What I'm trying to say is, Yes, it fits with the right ball joint. Remember to get an alignment when you're done.
