Most times you can go to a paint shop and rent the boot pretty cheap, especially if you can wait until they're not busy.mikeinaus wrote:
like i said i dont have a garage, and spraying a car outside on the street in my city probably wouldnt go over well...
Paint suggestions?
- Inodoro Pereyra
Re: Paint suggestions?
Diogenes of Sinope.
Diogenes of Sinope.
- mitmaks
I hope you don't expect this paint job to last long time, cause it won't.
ive seen pics of 5+ year old rustoleum jobs that still look great. marine paint should last even longer since its designed to be used in constant salt water conditions.
- solo_ryder
u on crack? lolmikeinaus wrote:you gonna sell me your shell for $250??? or how about you throw your shell in with your motor
why yes, i thought xmas would be the perfect time to start hitting the pipe
- MrMazda92
You aren't the only one, I won't drive down the street the way people "drive" in this city during the holidays. Parking's a big one too... If you can't park a car between the lines, chances are you can't drive it between them either. People...mikeinaus wrote:why yes, i thought xmas would be the perfect time to start hitting the pipe
